StefanT
WEbDav Problems
I chenged to Enpass6 and now Webdav-Snc fails all the time....error: Password/username not correct.........I changed nothing...Please help!!!!
...connection without folder works...but when I set up a folder it says password etc. not correct?????????????????????
Edited by StefanT
Share this post
Link to post
Share on other sites
I also couldn't connect to my custom owncloud with webdav as I was used to do with 5. It seems to accept my account and password, but then says it couldn't find the Enpass safe. I suppose it is looking in a different place than before.
I had to download the Enpass vault and import it manually. Haven't figured out how to make the WebDAV connection yet.
Share this post
Link to post
Ok, I managed to connect. The name and file type of the vault changed. It used to be 'sync_default.walletx' and it is now 'vault.enpassdbsync'. Just manually download and import your old database and set up a new sync instead of trying to connect to an existing one.
Would have been nice if this was communicated clearly in the install process.
Share this post
Link to post
What a shame:  ENPASS!
It ist NOT possible to export JSON form EP5! EP6 can import JSON! But if you import csv / txt file it will NOT organize it! And if there were no other EP5 version to export csv BEFORE installing EP 6 then.... you will loose your passwords? Is this real???
So I had to export from another PC to csv and had to import to EP6 as unorderd list of passwords. Almost 500...
At least I bought EP6 pro to check if there is a way to import the older wallet db: but there is non as well! Dark mode won't work on my PC... by the way !
Shame on you again Enpass to bring such a alpha version to the people! I guess I will leave enpass now in order to miss the same kind of trouble and work when it come to V7!
Still can not understand that and still very sad and angry !
Share this post
Link to post
Hi @StefanT,
Sorry for the inconvenience.
If you are using a self-signed certificate you need to check "Bypass SSL certificate check". Also, please PM me a demo webdav account(if possible at all).  It will help us to fix the issue faster.
Share this post
Link to post
It's not a problem with self-signed certificate.  I have a good cert from LetsEncrypt.  Still, I tried checking the "Bypass" box, and even still, it's no good.  Enpass 6 crashes as soon as I try to set up WebDAV.  Same exact setup worked fine with Enpass 5.x.
Share this post
Link to post
uninstalling enpass 6 once more (and all of the related folders) and reinstall it again solved my problem this way: took one backup file from EP5 and after installing EP6 the second time I told EP to take the backup and not the webdav folder. AFTER the backup came up completley I connected it with the webdav folder on my synology.
This gave me the advice I needed:
Share this post
Link to post
I also tried using webdav to sync data on Enpass 6, but always crash,
I found in the server debug that the password passed by enpass 6 is inconsistent with the password I entered, which is obviously a problem.
Before that, enpass 5 is all right, I mainly use mac os & iphone xsm.
Share this post
Link to post
10 hours ago, Vinod Kumar said:
Hi @StefanT,
It's not a problem with self-signed certificate....I tried all possibilities.......
Share this post
Link to post
Sorry to chime in here as well but I don't have the wrong Webdav URL as it is working fine if I paste the URL in a web browser and yet Enpass 6 OS X crashes as soon as it tries to Sync [I got to settings right away and it's fine until it starts Synching and then dies/crashes] and the Enpass 6 iOS version shows Synchronizing..   [spinning circle] which never goes away - even after 10 minutes - I tried it once...
Used to work fine under Enpass 5.x - I definitely prefer the functionality/design of 6 but without synching :/ very little use for me ;( also I wrote it to support because Pro isn't being understood for iOS / Restore Purchase by the app even though I am signing in with the same AppleID
btw when you try to submit a reply here when using Safari: Forbidden - Browser appears to be a spambot?!?
not ideal...
Share this post
Link to post
Hi guys,
Sorry for the inconvenience you had to face. We have fixed some issues related to webDAV in the latest iOS version 6.0.1. Soon we will be rolling out the update on other platforms too.
Thanks for your cooperation!
Share this post
Link to post
Update 6.01 on ios .........it is not funny any more!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PLEASE FIX IT!!!!!!!!!!!!!!!!!!!!!!!!
Share this post
Link to post
Hi there,
iOS update to v6.0.1 isn't working for me either with a Sync Error - No data found even though I checked via SFTP and there is a vault.enpassdbsync file in that location! :(
I emailed support about it... and they said there should be a fix on top of v6.0.1 coming soon [cross-fingers]
Looking forward to an actually working v6.x because as is, really can't use it yet and I'd really like to :)
Complaint of Sync aside, version 6 is DEFINITELY an improvement on version 5
Edited by Merlin
Share this post
Link to post
....I gave the support team a test-webdav account...........but no answers or info from support since wednesday.....same webdav error "904405" on 6.02 on ios and osx.....now no syncing for one week..............that's a shame.........!!!!!
Share this post
Link to post
HI StefanT, I received this the next day after submitting a test account:
"Thanks for providing demo account. Yes, we encountered problems with  it. We are on it and fix these. It has been a bit late and fix won't be available in tommorow's update.  It will be part of next week's update. "
So, while I understand it's frustrating, I think they are actively working on it... maybe your fix will be in tomorrow's update if you are lucky otherwise next weeks ;)
Cheers,
M.
Share this post
Link to post
Great news here!!!
WEBDAV-Problem on my Synology Nas was that there are blanks in the folder name!  So, you have to replace the "blanks" with "%20" and then it worked for me . For example:Folder name is "My Folder" .....so you have to replace it with "My%20Folder" in the Webdav-Adress.....
Same thing in ios and osx versions of enpass......sync in both now working for me!
Support says it will be fixed in next update....
Thanks to support!
Share this post
Link to post
Update to v6.0.2 on Mac OS X still NOT working -
1st Sync, says:
Sync Error
No data found on Webdav,
then I hit Resolve Now and then Continue and it says
Last Synchronized:
a few seconds ago...
if I hit Sync now again, it's back to
Sync Error
and if I hit Resolve Now and then Continue and it's back to saying:
Last Synchronized:
I of course check the WebDav location via SFTP and the data is there the entire time
so still messed up with improving slightly at least no longer crashing during sync? :/
Cheers,
M.
Share this post
Link to post
I have still the same issue, Nextcloud X Webdav, synchronized from Enpass on Windows and tried to connect on iOS.
The Enpass folder is there.
Edit: I tried both, the iOS latest Testflight Version and the stable from the AppStore.
2019-01-24 11_47_29-Enpass - Dateien - ownCloud - Firefox Developer Edition.png
Edited by matz
Share this post
Link to post
Hello everyone
i also had problems with WebDAV on Synology. For me I solved it that when I configured a new client I set it up as a new vault with the identical password but without sync (so blank). Then I configured the sync and it worked. So not restore, but create new vault and then sync it. Hope that helps.
Edited by Hardy
Share this post
Link to post
Using "%20" in place of the space character fixed my WebDAV sync... until I updated to the latest Android update (6.0.3.1).  Now WebDAV sync is broken again ("Could not connect to specified WebDAV folder").
I tried using a space character instead of the "%20", but I get the same error.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
