October 30, 20197 yr I am attempting to add a PIN for Quick Unlock but I am receiving the word Error in red when I click the Done button. I have enabled the logs and retried but it states there is no content after I reproduce the error. Attached is a screenshot. I am positive the two match as I clicked on the eye icon to see them.
October 30, 20197 yr More info might be helpful, such as: OS and version (e.g. Windows 10 Pro 1903, macOS Mojave 10.14.6, etc.) Enpass edition and version (e.g. traditional Win32, 6.2.0 [539], etc.)
October 30, 20197 yr Author Sorry for the lack of info. OS - Ubuntu 16.04 Enpass Desktop Version - 6.2.0 (537)
November 1, 20197 yr Very odd. I unsuccessfully tried to reproduce with Enpass 6.2.0 (537) on a Ubuntu 16.04.6 LTS (64-bit) install. Take a backup in Enpass, then maybe try this at a terminal?: $ pkill -i enpass $ sudo apt-get purge enpass $ sudo apt-get install enpass That would effectively reinstall Enpass.
November 1, 20197 yr Author Thanks for the reply. did a backup and I executed those commands. When I ran Enpass again it did not run as a first run. It asked me for my master password. I was expecting with a purge that it would have erased the database. I'll attempt the commands again and will wipe the data folders in between.
