November 19, 20196 yr So not every website allows for the same maximum password length. For example, Apple allows 32 characters (largest they have ever accepted for my accounts), Netflix accepts up to 50 characters (from what I remember), Google and Facebook both allow 100 character long passwords (the largest passwords that I have tried). Now, I use the Enpass password generator to generate the passwords and I can customise it to fit my preferences (such as minimum/exact number of upper case letters, digits and symbols. However, I have to keep changing the preferences based on websites. Now when I decide to change my passwords every couple of months, it's quite a pain to change the preference for every website (I have about 380 saved passwords!) For example, I prefer my Google and Facebook accounts to have exactly 25 upper case letters, 25 digits and 25 symbols. For AppleID, it's 8 of each (32 character password length in total), and so on. It would be great to have an option where Enpass remembers the preferences for each website from the last time the password was changed/from the last password that I used. That would make life so much easier.
October 30, 20206 yr Hi @Nilanjan Thanks for using Enpass and writing to us. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
