System tray icon resolution in Linux Mint
Hi @Yevhen Kushnir,
Welcome to the forums!
That really looks ugly! Could you please share the screen resolution of your system's display, and did you try restarting Enpass to check if that icon's appearance changes?
Thanks for your co-operation.
I have similar issues on all my laptops
  • Dell Latitude 5490, 14", 1920x1080
  • Dell XPS 9560, 15", 3840x2160
But at the same time it looks ok on my HP 250 G6 on its internal display and external monitor as well — 15", 1920x1080
All three laptops has Linux Mint 19.3 with all updates installed.
Quote
I have been using enpass almost for a year:-)
I will be glad to provide you with all necessary information.
Edited by Yevhen Kushnir
Hi @Yevhen Kushnir
Thanks for sharing the details.
I have noted down this issue and notified the concerned team to look into it. Hopefully, a fix will be available in the future updates. If there's anything else, let me know.
Thanks.
You can see screenshot from my Dell Latitude 5490 below. As you can see main application interface is extremely big — I believe it is related to icon size issue.
UPDATE:
I use latest 6.3.3.601 version.
image.thumb.png.267a7d6b8860bf4e9dadd945ec3f858c.png.
On 1/29/2020 at 7:19 AM, Pratyush Sharma said:
Hi @Yevhen Kushnir,
Please follow the steps mentioned in this FAQ and let us know if the issue persists.
Thanks!
It works like a charm! Thank you!
