February 20, 20206 yr Enpass stopped working on my android phone. Worked ok yesterday but today receiving error message every few seconds.. 'Enpass has stopped'. Tried uninstalling and reinstall (twice) but problem persists. Was offered the options to Close app even though its not open, or send feedback. I have pressed 'send' to feedback option but was unable to type anything as the error prevents me from typing due to constant pop-up.
February 20, 20206 yr Hi @spike Could you let the developers know which handset you have, the version of Android etc so that they may better help you.
February 24, 20206 yr Hi @spike, Sorry for the inconvenience caused to you. Could you confirm the Enpass version you're using? Is it the latest Beta version? Thanks!
