April 12, 20206 yr I'm using Linux, and I want to input a master password automatically on login. I think it's good if Enpass can be passed a master password from stdin like this: # store password to GNOME Keyring secret-tool store --label "Enpass master password" type enpass # set this command on login sh -c "secret-tool lookup type enpass | /opt/enpass/Enpass --pw-stdin" Could you consider this function?
April 14, 20206 yr Hi @shimataro, Welcome to the forums! We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
September 5, 20206 yr This would very useful, because it would allow integrating enpass with gnome-keyring or kwallet on linux. It would be basically linux equilevant to windows hello support, because you could use biometrics to login and then automatically open your vault on login.
September 7, 20206 yr Hey @Chrysostomus We appreciate your feedback on the same. Please note that we already have a feature request for it, which is aligned for implementation in the future. Thanks for your valuable suggestion.
