April 16, 20206 yr In the main Enpass screen, if I click on a tag, the list is filtered by that tag. I'd like to see the ability to chose more than one tag (using Ctrl key for example) and have the list filter by Tag1 AND Tag2. So if I applied to each card a tag that said Fred or Maybell and applied another tag that said Home or Work, then I should be able to show Fred AND Work. If you really want you could allow other boolean variations. One straightforward way of operating this would be allow boolean operators in the search field, and add Tags as one of the options in the search field dropdown. Thus I could search for Tags: 'Fred AND Work'.
April 17, 20206 yr Hi @ddken, Thanks for contacting us. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
