July 30, 20206 yr Hello, I am using the latest Enpass on Windows 10. The issue I have noticed is that scaling looks off with certain items very large or certain very small. Due to this I applied this fix: https://www.enpass.io/support/kb/troubleshooting/enpass-looks-too-small-or-big-on-my-display-how-can-i-fix-it/ Although after setting this setting the Enpass application becomes very laggy ... all the animations run very choppy and overall the application becomes slow to use. So I went and disabled the setting and the lag from the application finished. Can we get a permanent fix for scaling without side effects?
July 31, 20206 yr Hi @Danial We are sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. Which Enpass version are you using on the same device? The screen resolution and scaling you have set up? Thanks.
August 1, 20206 yr Author Enpass version 6.4.2 (669), non windows store version 1080p resolution with 125% scaling. Edited August 1, 20206 yr by Danial
August 4, 20206 yr Hi @Danial, Thanks for sharing the details. If possible, please share the video of the issue with us on support@enpass.io so we can further investigate it. Also, let us know on which device and Enpass version are you using. Thanks for your co-operation.
October 22, 20206 yr Author Its all good, I fixed it by setting the following: QT_auto_screen_scale = 0 and QT_screen_scale_factor = 1. When I had set to fractional scaling like 1.25 then I noticed a large amount of lag and some pixelation but setting it to 1 has fixed the issue.
