August 11, 20205 yr I linke using the enpass assistant and copying the passwords into clipboard. Could you add a visual hint when copying the password via shortcut (shift-cmd-p). You are already showing that hint when I click on the copy password button, but I want to use enpass completely with the keyboard. Beste Grüße Clemens
August 12, 20205 yr Hey @clemensTyp Thanks for using Enpass and writing to us. We really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted and forwarded to the development team for further consideration. Thanks for the suggestion!
November 4, 20205 yr Author I just saw that you guys added this notification into enpass. Thanks a lot.
