October 4, 20179 yr can you implement global autotype? it basically means that enpass simulates keypresses to log into any application, not just website how this would work: user opens app (e.x. steam) user gets steam in focus and presses keycombo to trigger global autotype enpass detects name of application or application title enpass searches for matching entries, if 1 match is found, simulate keypresses for login (in 95% of cases: {username}{tab}{password}{enter}) this keycombo can be made to be configurable ( for example skype, where you'd need {username}{enter}{wait 100ms}{password}{enter} ) if multiple matches are found, enpass displays a window, letting users select the correct entry, and then autotype the login info if no matches are found, enpass pops up with a search field so users can search the correct entry to autofill ofcource, in the last case, enpass will also ask to remember the application title for that entry this is a feature i greatly miss in the current version of enpass, hopefully you can consider to implement this somewhere in the future. and hopefully you can implement this in Linux as well (since that's the main OS i'm using atm, aside from sometimes Windows kind regards, intuxikated Edited October 5, 20179 yr by intuxikated wrong place
October 2, 20206 yr On 10/4/2017 at 5:38 PM, intuxikated said: can you implement global autotype? it basically means that enpass simulates keypresses to log into any application, not just website how this would work: user opens app (e.x. steam) user gets steam in focus and presses keycombo to trigger global autotype enpass detects name of application or application title enpass searches for matching entries, if 1 match is found, simulate keypresses for login (in 95% of cases: {username}{tab}{password}{enter}) this keycombo can be made to be configurable ( for example skype, where you'd need {username}{enter}{wait 100ms}{password}{enter} ) if multiple matches are found, enpass displays a window, letting users select the correct entry, and then autotype the login info if no matches are found, enpass pops up with a search field so users can search the correct entry to autofill ofcource, in the last case, enpass will also ask to remember the application title for that entry this is a feature i greatly miss in the current version of enpass, hopefully you can consider to implement this somewhere in the future. and hopefully you can implement this in Linux as well (since that's the main OS i'm using atm, aside from sometimes Windows kind regards, intuxikated
October 5, 20206 yr Hey @Saad Welcome to the forum! Thanks for using Enpass and writing to us. We really appreciate you for your exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted for further consideration. Thanks for the suggestion!
