September 11, 20206 yr Dear Forum, I updated today to V6.5.0. and have a small graphics problem. In the program but also in the browser-extensions the last parts of a line/headline are always cut off on the right side or bottom in the menu, in the single entries or generated passwords. It seems, a pixel row is missing. The problem occurs in the traditional version as well as in the store version. I use Windows 2004 (latest update) and a 4k resolution. The error is independent of the text scaling size. I have included two screenshots. This error occurs only with ENPASS. Does anyone have an idea what could happen? Cheers RUDI Edited September 11, 20206 yr by Rudi
September 14, 20206 yr Try this troubleshooting steps @Rudihttps://www.enpass.io/support/kb/troubleshooting/enpass-looks-too-small-or-big-on-my-display-how-can-i-fix-it/
September 14, 20206 yr Author Thanks, but this does not help. I try this before posting my problem. As I wrote, it is independent of the text scaling size. I also tried different versions of my Radeon RX 570 drivers. Maybe Enpass has trouble with Windows 2004, with pervious versions of windows I never had any problems with Enpass. @Support-Team: any idea or are other users known with this problem? Edited September 14, 20206 yr by Rudi
September 15, 20206 yr Hi @Rudi, We will check it on the latest Windows update, and share the results. However, what is the screen resolution on your Windows system?
September 15, 20206 yr Author I use 4k resolution, 3840x2160, text scaling 200 % The error is independent of the text scaling size. The error also exists with lower resolutions Edited September 15, 20206 yr by Rudi
September 17, 20206 yr Hi @Rudi, We have taken note of this and our team is now analyzing into the issue.
September 17, 20206 yr Author Great, many thanks for the feedback. Does this mean you were able to reproduce this error with Windows 2004 and are now looking into it?
September 17, 20206 yr Author Accidentally posted the same message multiple times Edited September 17, 20206 yr by Rudi
September 18, 20206 yr Hi @Rudi, Thanks for writing back in. We are able to reproduce this issue at our end, and our team is working on it. Hopefully, the fix will be available in future updates. Till then, we will request you to please co-operate with us. Thanks!
October 13, 20206 yr Author @Samuela with all due respect: you surely had a different graphics problem than I described? Did you? V 6.5.2 (724) does not resolve the problem to me (Win Pro 64 bit 2004, latest updates, 4k resolution) @Pratyush Sharma so once again: any news in this matter, especially as you are able to reproduce this issue at your end
October 14, 20206 yr Hi @Rudi, Sorry for the trouble you are going through. Our team is working on this issue. Hopefully, a fix will be available in the next update. Until then, please co-operate.
October 15, 20206 yr Hi @Rudi, We need a little more input from you, so please let us know the following details. Are you facing this issue after the latest update? If no, then please let us know from which version you are facing this issue. Are you using a custom font? Are you using multiple monitors? Thanks for your co-operation.
October 15, 20206 yr Author @Pratyush Sharma 1) I guess the issue starts with uptade to Win Pro 64 Bit 2004 2) Yes 3) No, only 1 with 4k-resolution
October 16, 20206 yr Hi @Rudi, Thanks for sharing the details. Please let us know which custom font are you using so we can further investigate. Also, have you tried using system default fonts?
October 16, 20206 yr Author 8 hours ago, Pratyush Sharma said: Hi @Rudi, Thanks for sharing the details. Please let us know which custom font are you using so we can further investigate. Also, have you tried using system default fonts? @Pratyush Sharma sorry, my fault, I use windows 10 default font, I changed only scale to 200 %. Another scale e.g. 150 % or 100 % has no effect on this problem
October 20, 20206 yr Hey @Rudi Extremely sorry for the trouble. The issue has been noted and our team is working on it to resolve the issue. Please bear with us for the time-being. Thanks for the co-operation.
October 20, 20206 yr Author @Garima Singh If there is anything I can support, please do not hesitate to contact me. Enpass is a great tool that I wouldn't want to miss
February 8, 20215 yr Author On 10/20/2020 at 6:52 PM, Rudi said: @Garima Singh If there is anything I can support, please do not hesitate to contact me. Enpass is a great tool that I wouldn't want to miss @@Garima Singh Any news to this matter?
February 9, 20215 yr Hi @Rudi, Thanks for writing back. Our team is working on this issue. We'll keep you update once we hear from them. Thanks!
May 17, 20215 yr I am also seeing this issue. I only just saw it happen in the last few days, before that it was not present. In my case much more is missing than in Rudi's case, I have about 1/2 the character width missing and the bottom is cut on many lines of text, making it hard to use the program.
May 18, 20215 yr Hi @xyzzy, Sorry for the inconvenience caused to you. Please let us know the following details so we can help you better: On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Are you facing this issue after the latest update? If no, then please let us know from which version you are facing this issue. Are you using multiple monitors? Can you please try after restart? Thanks!
