December 6, 20214 yr Hello, I use Enpass with version 6.7.4 (933) and as Webdav share I use a Nextcloud version 23.0.0. The problem is, it is not possible to sync the shares. Enpass always said, that I should check my username and my password. So I debugged a bit and found out, that the share is easy to mount with a linux webdav client. Now I dived deeper: I checked the server side and found out, that there are no requests from my enpass client to my nginx reverse proxy (checked the access logs). I started a sniffer on my client site, and saw the following output: This looks like, that the client is not able to create a TLS connection. Maybe the ciphers are too strong? The logfiles in enpass are a bit confusing: Info: [HTTP] CURLSSLOPT_NO_REVOKE Info: [HTTP] Using AUTO Proxy detection Info: [HttpClient] https://nextcloud.lasse-wackers.de/remote.php/dav/files/lasse/ curlresultcode: 35 responseheaders: Info: [HTTP] CURLE_SSL_CONNECT_ERROR try again Info: [HTTP] ****Unable to verify server certificate ***** Info: [HTTP] CURLSSLOPT_NO_REVOKE Info: [HTTP] Using AUTO Proxy detection Info: [HttpClient] https://nextcloud.lasse-wackers.de/remote.php/dav/files/lasse/ curlresultcode: 35 responseheaders: Info: [HTTP] CURLE_SSL_CONNECT_ERROR try again Info: [HTTP] ****Unable to verify server certificate ***** Info: [HTTP] CURLSSLOPT_NO_REVOKE Info: [HTTP] Using AUTO Proxy detection Info: [HttpClient] https://nextcloud.lasse-wackers.de/remote.php/dav/files/lasse/ curlresultcode: 35 responseheaders: Info: [HTTP] CURLE_SSL_CONNECT_ERROR try again Info: [HTTP] ****Unable to verify server certificate ***** Info: [HTTP] CURLSSLOPT_NO_REVOKE Info: [HTTP] Using AUTO Proxy detection Info: [HttpClient] https://nextcloud.lasse-wackers.de/remote.php/dav/files/lasse/ curlresultcode: 35 responseheaders: Info: [HTTP] CURLE_SSL_CONNECT_ERROR try again Info: [HTTP] ****Unable to verify server certificate ***** It is confusing because the certificate is valid and the reason, why the TLS connection cannot be established, is not the certificate. Is there anyone who has an idea? Cheers, Etroska Edited December 6, 20214 yr by etroska
December 7, 20214 yr Hi @etroska, Welcome to the Enpass Community. Thank you for sharing the details along with the logs, I have duly noted your feedback and the same has been forwarded to the concerned team for further investigation. To iron out this issue please share the following details. On which Device (along with the OS version) you are facing this issue? Share the demo account of NextCloud (if possible) and share its login-id and password along with the URL. Note: For security reasons either share the demo account details in the personal message on Forum or mail us at support@enpass.io (add your forum link and username so that we can identify you). #SI-2490
December 7, 20214 yr Author Hi @Gulshan Dogra, Quote On which Device (along with the OS version) you are facing this issue? On my Desktop PC I use Windows 10. My mobile device (same error) uses an iOS 15. Quote Share the demo account of NextCloud (if possible) and share its login-id and password along with the URL. I emailed you.
December 18, 20214 yr Author Hi @Gulshan Dogra, Do you have new information about this enpass problem? cheers and merry Christmas, Etroska
January 4, 20224 yr Author Ok. I found the Problem. In short; Enpass is not able to communicate with TLS1.3 Webdav shares. I thought that already, and I changed the virtual host in my nginx configuration to TLS1.2. After that, the webdav share was still not able to connect. Now we come to the part that I don't know yet: I had two configuration files in my nginx reverse Proxy: [root@server ~]# ls -1 /etc/nginx/conf.d/ 01-website.conf 02-nextcloud.conf In the 01-website.conf file, I set the TLS setting to tls1.3: ssl_protocols TLSv1.3; In the 02-nextcloud.conf file, which is responsible for my nextcloud instance, I set version 1.3 and 1.2: ssl_protocols TLSv1.3 TLSv1.2; Now I thought, that the virtual server for nextcloud is able to communicate with TLSv1.3 and TLSv1.2. But this is unfortunately wrong. Nginx takes the first configuration file, in my case 01-website.conf, and enabled only TLSv1.3. All other methods are disabled now for all virtual hosts. I thought, that the server name indication ensured, that nginx will offer the settings (TLS1.2) from my 02-nextcloud.conf. But I think, that the server name indication will take effect after the first TLS connection. So the only available TLS version is TLSv1.3. What I did: I created a new file 00-defaults.conf and enabled TLSv1.2 and TLS1.3. In the 01-website.conf I enabled only TLSv1.3 In the 02-nextcloud.conf I enabled TLSv1.2 and TLS1.3. Now I was able to connect via TLSv1.2 against the nextcloud virtual host and the webdav sync worked. Cheers, Etroska
October 8, 20224 yr In your iPhone's Settings app, go to Privacy > Local Network. Find Enpass in the list of apps, and turn on the Local Network Access option. If Enpass does not appear in the list, return to your Enpass app, reconnect the WebDAV sync, and allow permission. Regards, James
November 9, 20223 yr Use Commander One. https://ftp-mac.com/mount-webdav-mac/ Edited November 11, 20223 yr by Adamdd
