June 5, 20224 yr Both OneDrive and Dropbox refuse to login and the app says it was cancelled by the user
June 6, 20224 yr Hi @Nyagaka254, Please share the following details so that we can assist you better in this. On which all devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Share the screenshot any error messages or codes you are getting during the sync. Does the last synced time get updated on the sync page?
June 8, 20223 yr Author On 6/6/2022 at 12:49 PM, Gulshan Dogra said: Hi @Nyagaka254, Please share the following details so that we can assist you better in this. On which all devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Share the screenshot any error messages or codes you are getting during the sync. Does the last synced time get updated on the sync page? I've tried with Dropbox, OneDrive and Google Drive. All saying same thing The desktop app is fine. The issue is on the mobile app. I'm using v6.8.2.6666 on OneUI 3.1 Android 11
June 8, 20223 yr @Nyagaka254, If you are able to access the Enpass database on any device which is connected/synchronized with the OneDrive then follow the below-mentioned steps and share your findings with me. Take a manual backup of the Enpass database on all the devices. Disconnect the sync on all devices. Open your OneDrive account in any browser then remove the Enpass & Enpass 1 folders from the OneDrive account. Re-set up the sync with OneDrive on all the devices and check. Now after re-syncing with OneDrive, try to restore your database on Android device.
June 8, 20223 yr Author 6 minutes ago, Gulshan Dogra said: @Nyagaka254, If you are able to access the Enpass database on any device which is connected/synchronized with the OneDrive then follow the below-mentioned steps and share your findings with me. Take a manual backup of the Enpass database on all the devices. Disconnect the sync on all devices. Open your OneDrive account in any browser then remove the Enpass & Enpass 1 folders from the OneDrive account. Re-set up the sync with OneDrive on all the devices and check. Now after re-syncing with OneDrive, try to restore your database on Android device. Still doesn't work. I've discovered the problem might be Vivaldi. I've tried to restore the database and used chrome instead of vivaldi and it worked. The problem is with vivaldi, I'm not redirected back to the app
