June 6, 20224 yr Hello. I am looking for a password manager with a sync between different devices (iPhone, iPad, Mac, Windows) without cloud. One of the few solutions that can do this is Enpass. Unfortunately only half of it. On my computer, for example, macOS and Windows are installed on the same machine. Therefore, only one of the systems is on at a time, so Enpass cannot synchronise them via Wifi. This is a pity. It would therefore be nice if all versions, especially the iOS version, had the Wi-Fi server function. Best regards Hauke
June 6, 20224 yr Author Just had the idea to use "folder sharing" to share between macOS/Windows and use Wi-Fi-Sync to share with iPhone/iPad, but that is Enpass not allowing at the same time ... :-/
June 7, 20224 yr Hi @hauke Welcome to the Enpass Forums. You can only synchronize your vault through one method at a time, i.e., via a cloud server, WiFi sync or Folder sync. Regarding the mobile device acting as a Wifi-Sync server, I have duly noted your comments and shared them as feedback with the dedicated team so they may check the feasibility of the requested feature and implement it for the future Enpass version. Your patience in the meantime is appreciated. #SI-2911
December 17, 20223 yr Author @Abhishek DewanAny update? :-( Let mobile app version action as a wifi-sync server would be the perfect solution.
December 19, 20223 yr Hi @hauke Our dedicated team is already aware of this feature request and they are checking its feasibility. Unfortunately, I will be unable to share any ETA right now but rest assured, I'll be sure to notify you when this feature is released. Your patience in the meantime is appreciated.
