July 8, 20251 yr Just updated to macOS Tahoe Beta 3 and enpass desktop doesn't work with this version either. Same symptoms and issues as Beta 2.
July 9, 20251 yr deltarune On 7/8/2025 at 12:47 PM, Syd said: Just updated to macOS Tahoe Beta 3 and enpass desktop doesn't work with this version either. Same symptoms and issues as Beta 2. Enpass isn't yet compatible with macOS Tahoe Beta 3. You can try downgrading macOS or use Enpass in a virtual machine for now. Hopefully a fix comes soon! Edited July 9, 20251 yr by precludehunter
July 9, 20251 yr On 7/8/2025 at 12:47 PM, Syd said: Just updated to macOS Tahoe Beta 3 and enpass desktop doesn't work with this version either. Same symptoms and issues as Beta 2. Enpass isn't yet compatible with macOS Tahoe Beta 3. You can try downgrading macOS or use Enpass in a virtual machine for now. Hopefully a fix comes soon!
July 12, 20251 yr Maybe one of the Enpass members can tell when it will be OK again. Last time it took too long...
July 12, 20251 yr Author I'm running the latest beta 6.11.13 (2028) and it's working for me. You can get it on their beta web site https://www.enpass.io/beta/
July 12, 20251 yr Rosetta needed?!? I installed now the Testflight version. Edited July 12, 20251 yr by longtom
July 14, 20251 yr We are excited to announce that we’ve addressed this issue in our latest Enpass macOS beta release: https://www.enpass.io/beta/ For the Enpass App Store version (requires macOS Monterey 12.0 or later), you can join our TestFlight program to access the beta. Alternatively, you can download the Website version of the Enpass macOS beta. Thank you for your patience, and we’ll notify you as soon as a stable update with the fix is officially released.
July 15, 20251 yr Enpass TestFlight Beta 6.11.13 (2028) working great so far on macOS 26 (25A5306g) Beta 3. Thanks!
August 21, 20251 yr Enpass 6.11.13 is working fine under macOS 26 Tahoe beta 7 developer. The only thing that is sort of an (old) issue is that multiple icons are showing up again in the dock, as they did a few versions ago. One thing that has to be addressed for the future is to make the installer Silicon native. It still needs Rosetta, and Intel support should be gone with macOS 27, according to Apple. I know that is a year away, but in the past enpass has sometimes taken forever to fix things that should have be corrected in a matter of days.
August 22, 20251 yr Thanks for confirming that Enpass 6.11.13 is working well on macOS 26 Tahoe beta 7! About the dock icon duplication, we weren’t aware of this behavior in the current build, so your report is very helpful. Could you please share a few details (steps to reproduce, any patterns you’ve noticed) so our team can investigate?
August 22, 20251 yr 9 hours ago, Amandeep Kumar said: Thanks for confirming that Enpass 6.11.13 is working well on macOS 26 Tahoe beta 7! About the dock icon duplication, we weren’t aware of this behavior in the current build, so your report is very helpful. Could you please share a few details (steps to reproduce, any patterns you’ve noticed) so our team can investigate? Hi Amandeep Kumar, First, I have "Hide dock icon when the main window is closed" selected. But the icon in the dock is not hidden, it is just not active (no more dot under the icon). In the images below, the 1st one is with the enpass window open, in the second one the window is closed. After a system restart, when the enpass window is opened you can see 2 icons. And the active enpass icon is not the latest one to show up (on the right), but the one that was active before the restart (on the left): The 2 icons are still seen after the enpass window is closed again: After opening/closing the enpass window a few times, I can see more than 2 enpass icons in the doc. This time, the active icon is the latest one that showed up (on the right side): It does not seem to create several enpass icons at once, as it was the case a few years ago. Let me know if you need more information. Note that I have only the last 8 recent applications showing up in the dock.
August 25, 20251 yr Hi @fermati, Thank you for sharing these detailed observations and screenshots. This information is very helpful. We’ve forwarded your report to our product team for further investigation. We’ll update you here as soon as we have more insights to share. #SI-4476
August 27, 20251 yr Hi @fermati Thank you for your patience. Please confirm if you are using the Enpass app store version or the website version on the device where you’re experiencing the issue.
August 27, 20251 yr Author I'm running Enpass version 6.11.13 (2028) - Mac App Store and it's working fine on macOS 26.0 Beta 8 (25A5349a)
August 27, 20251 yr 7 hours ago, Tarun Singh Rawat said: Hi @fermati Thank you for your patience. Please confirm if you are using the Enpass app store version or the website version on the device where you’re experiencing the issue. Hi Singh Rawat, I am using the website version.
August 29, 20251 yr We appreciate you taking the time to provide this information. It’s now with our tech team, and we’ll be in touch once we have further updates.
September 5, 20251 yr @fermati Thank you for your patience! To ensure optimal performance, please update the Enpass app to the latest version (6.11.14). Additionally, if possible, please update your macOS to the latest beta version available.
September 5, 20251 yr Hi Tarun Singh Rawat, Thanks for your post. I am now testing Tahoe beta9 with enpass 6.11.14, and at the moment there are 3 enpass icons in the dock.
September 9, 20251 yr @fermati Could you please confirm if you have closed all Enpass icons from the dock and then restarted your device? After restarting, test again to see if multiple dock icons still appear.
September 9, 20251 yr I followed your suggestion: I removed all enpass icons from the Dock, restartied the Mac and opened enpass. I then closed the enpass window (command-W). The enpass icons does not disappear from the Dock, although "Hide dock icon when the main window is closed" is checked in preferences. At first, only that remaining enpass icon was activated (little dot below the icon) upon making the enpass window active again. But after several times of closing the window and reopening it, several enpass icons were left in the Dock.
September 10, 20251 yr Thanks for checking this and sharing the detailed steps with us. We’ve noted your observations and will be sharing this with our product team for further investigation. We appreciate your patience and will keep you updated on any progress.
