owncloud central
Auto-submit seems to be broken.
If I set the auto-submit login option on the item in Enpass then pressing Ctrl+\ correctly fills the login fields but then displays a "[BAD CRSF]" message.
If I un-set the auto-submit login option then pressing Ctrl+\ fills the login fields.  I then click the Login button manually and it logs in correctly.
url: https://central.owncloud.org/
Hi @Richard,
Thanks for reporting the issue. We have noted it down and try to fix this issue asap. Please bear with us!
