August 2, 20188 yr The beta of Enpass 6 obviously has a very high energy consumption. Even if the software runs in the background, the application is displayed accordingly in MacOS. In addition, according to the activity display, the setting "Requires a high-performance CPU" is set to "YES". This should be solved urgently (not the display, but the underlying behavior of the app).
October 3, 20188 yr I see this as well. 0.5-1.0% on my 6 core machine is way too much for an idle process with not even a window showing....(and sync is also not set up).
October 4, 20188 yr Hey guys, This issue has been fixed and you will get it in the next update. I would like to have your feedback after the update. Thanks for your patience.
October 10, 20188 yr On 10/4/2018 at 3:50 AM, Anshu kumar said: Hey guys, This issue has been fixed and you will get it in the next update. I would like to have your feedback after the update. Thanks for your patience. If you are talking about 6.0.0 220, then yes you are right, the power consumption when in the background is down to between 0.0% and 0.1%. Thanks to the team for that!
