August 7, 20188 yr Would sometime care to comment about integration to Box in the Android version app? It doesn't appear to be there as an option but it's in the current stable version. Please don't tell me support is being dropped, as I'll have to let it go if that's the case
August 8, 20188 yr Hi @Richard2016 Thanks for writing in. You can sync Enpass 6 data to Box cloud via WebDAV sync. To connect WebDAV please use the following Server: https://dav.box.com/dav using your Box login email address and password. Note: Web browser access is not supported. You need to use a WebDAV client. Cheers! Edited September 17, 20188 yr by Anshu kumar Added the sync support through WebDAV cloud in v6.0.0.58
December 28, 20187 yr Hello @Anshu kumar Hello Why is not it possible to synchronize as a web browser. And the WebDAV is just as secure the web browser synchronization. enpass is so good i love it! THX for response
