August 13, 20188 yr Hi, I'm trying to setup the Sync with WEBDAV. But it's not working ... I'm using Enpass 6.0.0 (187) Beta on Mac OSX. I checked that the WebDAV is working using Mac Finder and entered the url: https .... PORT(5006)/media and I was able to connect to my folders. When entering the same URL and user/pw into Enpass it tries to sync but then I get a failure: Error -102. (I checked the box to ignore SSL certificate validation, even if the validation should be fine as the cert is issued by Let's Encrypt). If I go for http instead https it's working fine using the same URL schema: http .... PORT(5005)/media. Also interesting is that the sync time is listed as year 1970 (see screenshot) for the http sync. This could cause the issue for certificate validation? Sidenote: on Enpass 5.6.11 it's working also fine even with https url. So, it's only a beta bug! Regards, Michel
August 13, 20188 yr Can confirm the issue with https (Port 5006). But the date issue seems to be a specific issue on your side (maybe NAS?). As you can see in my screenshot, correct timestamps are used....
August 14, 20188 yr The timestamp looks like the "default" time, when no value is set. (also see unix time wiki) So I would think there might be a bug with setting the correct timestamp that is somewhat correlating to his previous sync via https. But this is just an educated guess
