[BUG] Username not saved
Hello.
I'm having an issue with one website: https://cliente.portoseguro.com.br/portaldecliente
When I log in, the Chrome extension pops out asking me to save the information. Them problem is: only the password gets saved ("Digite sua senha" field). The username ("Digite seu CPF ou CNPJ", something like "Type in your SSN") do not gets saved.
As far as I could investigate, this field is an
<input type="tel">
and this might be the problem, but I'm not sure (neither think it's right).
Hi hartungstenio,
Thank you for reporting this issue. We will review the problem and will try fix the issue asap.
