December 21, 20169 yr Hi folks, I'm a mostly happy EP user on Linux and android. Updating the desktop app is nearly not possible, since there is no possibility to start the maintenance tool from the app. Do you think about a way to start the update process manually from inside the app? Or to provide a rpm? *hint* *hint* Nice work, bye andre
January 17, 20179 yr I have found that on Fedora (24 and 25) the update 'tool' or 'option' does not function but if you perform a new install it will pick up all the configurations that were in place for the previous version. At least this happened going from v5.3.0 to v5.4.1. It was necessary to install the new version in a new location since the installer detected the existence of the previous location and was not able to over-write it. If we aren't going to see and RPM (yum or, preferably, dnf) installation option then allowing the installer to over-write the old version (after warning this is happening) would be a very helpful change. Appreciate the tool, keep up the good work.
