September 10, 20197 yr I've installed Enpass, through the hellish Microsoft Store as a download is not available. When running for the first time, I'm given an option on sych online via DropBox. After so sketchy Firefox integration, it fails with a "Something went wrong. Error -1" It seems the Enpass developers have taken cues from Microsoft for giving insightful error messages. So it won't work, it wont sync. Help please. Windows 10 - brand new install. Same with Firefox Edited September 10, 20197 yr by Dougga Config update
September 10, 20197 yr Hi, I am a user only. I had trouble syncing across dropbox but not TO dropbox. Under the vault setting, is the SYNC now button shown? What does it say under the LAST SYNCRONIZED field? So far, Sync is working for me also using brand new Win10 install;
September 11, 20197 yr Author The most basic installation won't work given I'm trying to populate the application with my DropBox Synced data.
September 11, 20197 yr Hey @Dougga, Sorry for the trouble you're going through. Please follow these troubleshooting steps and let me know if the problem persists. Open Enpass --> It will display a welcome screen --> Select Create new --> Create a Password. Now Go to Settings --> Vaults --> Tap on Primary and enable sync with Dropbox. Hope this helps!
