September 13, 20197 yr Bonjours, Je ne parviens plus à utiliser Enpass depuis un petit moment (2 mois peut-être plus), suite à une mise à jours. la version principale ne s'ouvre plus du tous. la version beta ne parviens pas à communiquer avec l'extension de navigateur (j'utilise chrome) Merci pour cette application très utile et efficace (quand elle fonctionne ^^) Cordialement
September 13, 20197 yr Hey @Charlie, Sorry for the trouble you are going through. Please drop us an email at support@enpass.io along with these details so that we can check where the problem could be. Which Enpass and Enpass extension version are you using? Which Chrome version are you using? What error message or code are you getting when you click on Enpass extension icon? Also, please run this command in the terminal and share the results: lsof -i:10391 Where 10391 is the port number and if there is no output (blank), please try with other port numbers between 10391 to 10395. Thanks for your co-operation.
