September 21, 20197 yr Hello together, today my Mac updated automatically to Safari 13, so I switched from 1Password to Enpass, which I bought earlier this year exactly for this scenario. Import password (including attachments) from 1Password worked as expected and the extension for Safari also works when using the button in the menu bar. But I can't get any shortcut working on my German extended keyboard for the Safari Plugin, which is aware of the actual opened page. Setting any shortcut within the App (see second picture) for the Plugin does not work. Also setting the shortcut directly in the plist-file 7ADB8CC6TF.in.sinew.Enpass-Safari-Group.plist in the path Macintosh HD ▸ Users ▸ _my_user_name_ ▸ Library ▸ Group Containers ▸ 7ADB8CC6TF.in.sinew.Enpass-Safari-Group ▸ Library ▸ Preferences with the tool PrefEdit (see picture 2) does not work. My guess is that Enpass does not recognise the command-key ⌘ properly. I also quit every other tool of me (like BetterTouchTool etc. to be sure there are no interactions and reset all shortcuts within system settings. I'm not looking for the global hotkey as it opens the assistant which isn't aware of the actual opened page. That bug is really annoying and breaks my mostly keyboard-based workflow. Best regards Gee Edited September 26, 20197 yr by Gee
September 24, 20197 yr hi, you have to use an english keyboard layout to enter this key. 1. go to settings - keyboard and change your keyboard layout to english. 2. go into enpass settings and press that key (for example pressing # will show \) 3. if you switch your layout back to german the combination: cmd-alt-# should work.
September 26, 20197 yr Author Thanks @clemensTyp. But the global Enpass hotkey is not quite what I was looking for. I'm going to clarify my request in the first posting. I was looking to configure the Enpass hotkey used within Safari (Plugin), so that the password is filled in for the opened page according to the actual adress. In 1Password it was ⌘ + #. Best regards
October 18, 20197 yr Author There's a slight change, that makes the situation even a little bit more mysterious. Enpass shortcut within Safari is now working with Catalina and Safari 13.0.2 on my MacBook (German keyboard layout) but still not working with my iMac. Can the Magic Keyboard with Numeric Keypad - Space Gray (German keyboard layout) make that difference?
