Keyboard shortcut is unreliable
Windows 10 64bit
Chrome 51.0.2704.29 beta-m (64-bit)
Enpass 5.2.0
The keyboard shortcut is unreliable, especially for intranet sites. I have multiple very similar intranet sites, which all get matched correctly when I manually click on the extension (only one result), but the keyboard shortcut doesn't work for about half of them.
Let me know how to provide more info, as I realise this would be hard to replicate.
  • 1 month later...
To update this, the keyboard shortcut does work for every one of them, however not always on the first try. If I spam it, it eventually works.
  • 3 weeks later...
  • 2 weeks later...
Actually, I've discovered this issue has nothing to do with intranet sites.
It happens when the site loads in the background (tab is not active). Has been happening with all websites. If I refresh the page, it works first time. If the page loads in the background, this happens.
  • 4 months later...
Figured I'd update - this seems to be fixed for me in 5.3.0.1.
