September 28, 20197 yr Hi all Sometimes I want to Login Websites which needs the Loginname first after hit Enter oder click Next Button I come to the Site where I can enter the Passwort. On this sites The Autofill fails, it is entering the correct Loginname but not the Password. On Keepass you can configure the Login in a way like fill the Loginname,enter, Fill Password ,enter. Is there a way to do this Enpass? Best regards
September 29, 20197 yr On 9/28/2019 at 11:21 AM, farfraaway said: Hi all Sometimes I want to Login Websites which needs the Loginname first after hit Enter oder click Next Button I come to the Site where I can enter the Passwort. On this sites The Autofill fails, it is entering the correct Loginname but not the Password. On Keepass you can configure the Login in a way like fill the Loginname,enter, Fill Password ,enter. Is there a way to do this Enpass? Best regards Based on your spelling it looks like you encounter this on German sites. I have the same on Dutch (Netherlands) sites. To the Enpass people: does Enpass render these languages correctly? My presumption is it mistakenly adds the username or other data to the password field.
