October 14, 20197 yr Hi @Yoyi, Thanks for your message! Please note, the Enpass app is listed in the Microsoft store and since the Windows 10 supports all the apps listed in the Microsoft store, thus Enpass app can be used in the Surface X Pro. Please refer to the link for the same.
January 8, 20206 yr The Surface Pro X is an ARM device. As such, many Windows 10 64bit apps don't run unless they are specifically compiled to run on the ARM processor. Does Enpass 6 run on that processor?
January 10, 20206 yr Hi @RayR Thanks for writing in. Currently we don't support Enpass in ARM devices. However, we have future plans to support Enpass in ARM devices and we will update you if we have any information regarding this. Thanks!
