October 17, 20197 yr I've had Enpass on my windows phone for quite a few years now. Works perfectly and backs up to OneDrive. I've since been forced to abandon my WP for an android phone. I understand that I'll need a new license for the android app, no problem. What I am unsure of is how to migrate the data. I looked in my OneDrive acct and found the Enpass folder containing one file, sync_default.walletx. So here's the question... if I tell my android app to sync to OneDrive, will the file I now have be compatible, or will it be over written by a new blank file (and therefore losing all my data)???
October 22, 20197 yr Hi, this is easy. I understand your concern, but what you do is what everybody has done many times when a new device is added. It is described here: https://www.enpass.io/docs/manual-desktop/bnr.html#restore-from-cloud Just connect your Android App to your OneDrive, and tell it that you want to restore, not set up a new user. This is the difference.
October 26, 20197 yr And it wouldn't hurt to first Make a copy of sync_default.walletx Install Enpass desktop on Windows, Linux, or macOS Use the desktop application backup feature to take a backup. Then you can migrate to your Android phone with full confidence that you can restore if something goes south during migration*. *I once entered 10 puns in a humor contest, hoping one would win. Unfortunately, no pun in ten did.
