Sync Service folder and Data Location in same folder?
Hi, I posted a reply to a forum thread here: https://discussion.enpass.io/index.php?/topic/1271-difference-between-sync-options/
I am trying to clarify if I can have the Enpass "Data Location" be the same as the Sync Service folder (ex. /home/user/Dropbox/Apps/Enpass/).
Should I also turn sync on? Or is it recommended to have the "Data Location" be in a separate local only folder.
Thanks,
