October 26, 20197 yr Hello I do not have any synchronization between onpass application on my desktop and my mobile Best regards Regis
October 26, 20197 yr Did you configure Enpass for syncing via Dropbox, Google Drive, Microsoft OneDrive, Apple iCloud, or WebDAV?
October 26, 20197 yr Author Hi Monyker Thank you for your reply.I do it by Google Drive but I see 2 directories: enpass and enpass (2)But I have already tried to delete one and configure only one directory, I have again a second directory in my Gdrive disk.
October 26, 20197 yr Hmmm... It sounds like you are attempting to use Google Backup and Sync or Google Drive File Stream to sync Enpass? Enpass has integrated facilities for syncing with Google Drive, Dropbox, etc. When using Enpass' integrated syncing with Google Drive, no additional folders/files appear in your Google Drive. See: Vault Settings documentation (Set Up Sync, in particular) How is the new Google Drive sync working? Attempting to sync Enpass data outside of the application (e.g. using Backup and Sync directly), will almost certainly not work as desired.
