Unable to reset Enpass
My Pixel XL went bad and I received the replacement from Google today.
Once the phone was finished with restoring settings and redownloading the apps, I tried to use Enpass.
Instead of a welcome screen, I get the unlock screen ("Master Password").  I forgot the password so decided to delete the backup on the google cloud.  Tried to find local files (searching for sinew or enpass) and only found "Android/data/io.enpass.app" folder, which is empty.
Opening Enpass, it gives me the unlock screen still, instead of the welcome screen.
How do I reset Enpass on Android, given I couldn't find anymore local related files to Enpass, and made sure the cloud backup has also been deleted?
Thanks!
