November 6, 20197 yr Hello All, Let me start that I am big fan of enpass against the countless password managers I used, I have an issue, I have one login info saved in vault and under that login info i have note which contains important data, for some reason the note got empty and I really need what's written on it, my only thought was since i sync it with gdrive and gdrive keep versions for last 30 days of files ususally is to get the copy of 24/october. thatsaid, the files are hidden there and I want to view them like normal file to get an old copy of file where my note is there. somehow enpass keep password history but not notes history :( Please help me with work around. Thanks, Alaa
November 7, 20197 yr Hi @Danz17 Thanks for using Enpass and writing to us. Please drop us an email at support@enpass.io along with these details so that we can check where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass extension version are you using? Thanks!
