May 18, 20179 yr There are some sites and apps that uses Google, Facebook, etc. as login, for those it will be great if one field could be used to link to the entry that has the password (like Google). Thanks - Javier
May 18, 20179 yr Why would you use that feature? You're using a password manager now. Compartmentalize your passwords. Use a different password, never the "login with Facebook" feature. If they do steal a password, they can only get into one site, not two or more.
