Sync fails: Errorcode 907403
I've been using enpass for about 2 years without major problems. I use enpass on 4 devices and sync my vault to my owncloud account. Since end of November the sync fails (Errorcode 907403).
Two major changes have been made: 1) I change my account to Pro; 2) I updated my owncloud to version 10.3 (from 10.1).
Thanks for advice
Michael
Edited by wottilarg
  • 1 year later...
I have the same issue since 2 months with syncing my webdav folder on my synology NAS via DynDNS.
For years I had no problems at all. It's the same on all my devices IOS and Windows. Did you/anyone found an answer to solve this?
Ok, just found the answer by myself one second later -> if anyone has trouble with this check extended permissions / extended settings on your webdav folder.
Cheers
