is Wifi Sync save?
I use Enpass on my Windows PC (main usage), Iphone and Ipad.
Because of a bug, the iCloud Sync does not work. As I have seen, there is a possibility to export a backup file to your mobile phone via the WLAN. My question is , is this methode safe and will the file you transfer on the link (the IP-adrees link, you have enter on the PC) is stored? Or will the file or the link be deleted directly after export on the phone?
