Sync via iCloud
Hello,
I have multiple different devices where I use Enpass.
On my iPhone as an example the sync via iCloud works perfect and syncs within 2 seconds. For my three PCs I press sync and it just loads for more than 30 minutes and nothing happens. I have tried to reinstall the program, then it downloads data from the cloud at installation, but then same issue when syncing after that.
Is there anything I can do?
Thanks!
Filip
Really enpassed? Why was the threat deleted?  Because people complain that the iCloud Sync doesn't work anymore? Honestly, this is an essential feature, and you don't test it before you deliver an update?
There is an existing thread already on this topic and they have released an update two days back which has fixed the issue
