June 29, 20179 yr Hello, KeePass has a (IMO) neat feature that you can right click an entry and then let it autofill. Enpass does that better with a real browser plugin, while KeePass can use autofill in desktop apps as well. I would find it really nice, if you could add this to Enpass as well. Right click on an entry inside Enpass and then it switchers to the last place you had your cursor in (I think that's how it works on KeePass) and then it fill the username and password in automatically Cheers Edited June 29, 20179 yr by Stahlreck
