Dropbox sync fails after sleep/wakeup on Mac
I've run into the following issue with Enpass v5.5.6 on macOS 10.12.5:
  • Dropbox sync is enabled and is working fine.
  • I leave the office, where I was connected to the Wifi network. I close my MacBook and get on the train.
  • On the train, I work on the MacBook, but not connected to a Wifi network. Before I exit the train, I close the MacBook again.
  • At home, I open the MacBook and it connects to my home Wifi network.
  • When I now make a change in Enpass, the Synchronize icon starts spinning and sync never finishes
The only fix for this is to quite Enpass and start it again.
Can you please verify whether this is a known issue, or a new bug?
Hi @nwinkler
Thanks for reporting this issue and I really appreciate the step by step description, it will help us to diagnose the problem. I have penned down this issue and forwarded to the dev team so they can try to fix it asap. Till then please co-operate with us.
