July 11, 20179 yr Simple one, i think. On the Windows log in screen (and every other place i think) I can press shift + home to select what's currently typed on the same line and just type it again. So, if i make a mistake on the password i press the key combination and just type it again. On the Windows desktop version of Enpass, if i make a mistake while typing the master password i cannot do this, and have to clear by pressing the backspace. Would be nice if it Enpass supported all standard Windows key combinations. Thanks.
July 12, 20179 yr Hi @julioc Thanks for writing in. Previously we had this feature in Enpass but for security improvements, we had to remove it. However, you can use Ctrl+A command to select password while unlocking Enpass keychain. Cheers!
