July 12, 20179 yr Hi, I have problem with few web pages and applications which detect how the password is filled to the input. If they detect filling credentials as one insert of whole string they just block sending form or notify you with bad credentials error. So I search how to bypass this irritating feature and I find that the others pass-managers use filling credentials "character-by-character" as if they were written by man. So is it possible add this style of filling to Enpass as a choice for each of entry? Thanks D. Edited July 12, 20179 yr by DazixCZ
July 13, 20179 yr Hi @DazixCZ Thanks for your suggestion. I have noted down your suggestion and notified the dev team about it. It would be a great help if you can share the name of the website (along with URL) so we can dig in for further improvements. Awaiting your response.
July 14, 20179 yr Author On 13. 7. 2017 at 8:28 AM, Anshu kumar said: Hi @DazixCZ Thanks for your suggestion. I have noted down your suggestion and notified the dev team about it. It would be a great help if you can share the name of the website (along with URL) so we can dig in for further improvements. Awaiting your response. There is a little bit problem with the url (https://ib.airbank.cz) because its a login page to my internet banking and Android app is banking app. But I can ask to my friends if they have some another page with this problem. Edited July 14, 20179 yr by DazixCZ
July 14, 20179 yr Hi @DazixCZ Thanks for writing back and sharing the URL. It seem's there is some problem with this website with the Auto-submit option and I have noted it and notified the dev team about it, Meanwhile, please disable Auto-submit Login for the particular item and manually click on the login button after autofilling. 34 minutes ago, DazixCZ said: But I can ask to my friends if they have some another page with this problem. Yaa! it would be great. Cheers!
