5.1.5 Beta
Auto fill from notifications crashes app. It will let me select the notification and get into my enpass app to select the stored info to use. Once it goes back to the website or app I'm trying to fill the password for, I get the crashed message.
Hi @DoughP,
Thanks for being a part of Enpass beta program & reporting the issue. Please provide these details for more investigation
  1. Device on which you are using Enpass?
  2. Android OS version on your device?
  3. Does this happen for all websites/apps when you try to autofill using Enpass?
  4. Does Enpass notification fill the username/password before crash?
If possible, can you please make a short video of the crash.:)
LG G5
6.0.1
Yes, every website/app
No. No fill occurs before crash.
Hi @DoughP,
We have released new Enpass beta version 5.1.6 with some fixes for Autofill using Notifications. Please update your Beta build and let us know if it works.
Thanks!
It is working now. Thank you for following up!
