July 23, 20179 yr It would be a security improvement to delete the clipboard after some time (u having this featur already) OR after the password has been used - whatever event (time or password use) happens first.
July 24, 20179 yr Hi @TomTom81 Thanks for writing in. I would like to share that Enpass already has the option "Clear clipboard after" which clears clipboard when you copy any data from Enpass after a specified time interval (Which you set in Enpass). Cheers!
