Website that don't seem to work
Hi all,
a couple of days ago I started to test Enpass. On the first day I added a few logins into Enpass and everything worked fine.
While adding a couple more logins today I realized that some websites aren't working as supposed.
On these websites Enpass is unable to autofill the login credentials.
The usual procedure would be that Enpass autofills a login formula at a given adress, for example: https://discussion.enpass.io/index.php?/login/
But on these websites that I stepped across there seems to be another step or action involved:
Example #1 - https://www.syncfusion.com/ (Software Developer)
Nothing happens on this website. The problem is that before you can enter your login credentials you have to click "Sign In" at the top right corner.
Example #2 - https://www.stardock.com/accounts/login (Software Developer)
Enpass autofills the formula but it doesn't login. I receive the error message: "Please enter a valid email address." When I click on "Sign In" i get successfully loged into the website with the autofilled data.
Example #3 - https://www.tumblr.com/login (Blogging Platform)
Enpass autofills the formula but it doesn't login completely. The login name and the password are seperated. First you have fill in the email then click on "Next." The following windows wants you to enter your password and then you can click "Login".
Example #4 - http://www.share-online.biz/ (Filehoster)
Nothing happens on this website. The problem is that before you can enter your login credentials you have to click "Login" (Einloggen) at the top right corner.
Example #5 - http://www.smoozed.biz/ (Filehoster)
Nothing happens on this website. The problem is that before you can enter your login credentials you have to click "Login" at the top right corner.
This problem seems really persistant for me. During my two days of testing I added 30 website logins into Enpass and 12 of them are having this (or a similar) issue. If you need more website examples I can post them here. Please let me know if someone is aware of this issue or if there's a workaround / fix for it.
Thanks for your time.
Best regards,
EyoVox.
Hi @EyoVox,
Welcome to Enpass family!
Thank you so much for the explaining the scenario, it helped us to understand the problem clearly. Much appreciated.:)
I would like to share that Enpass autofill works only when the login credentials fields (username and password) are visible. The above sites that you mentioned don't display the username and password, that's the reason Enpass is unable to autofill. In this case, you'll have to manually click on the login option after that, when the username and password fields appear you can fill login credentials using Enpass browser extensions.
I have noted down these websites and notify the dev team for further investigation.
It would be great if you can share the Websites name it will help us in improving the Enpass extension.
Cheers!
