July 28, 20179 yr I have a website with TOTP, but the TOTP username is different from that site's username. I hope there could be a option of customizing TOTP username.
July 28, 20179 yr Hi @coderfox Thanks for stopping by and writing in. As far as I understood, you want to change the label for the TOTP field and that can be done easily and in-fact for any of the field in item. Hope this helps. Cheers!
July 29, 20179 yr Author No, I don't mean to do that. In TOTP spec, the generated code is relevant to username and key, but the username of TOTP is different from the login username. I want to custom the TOTP username.
