August 4, 20179 yr Just installed Enpass and paid for pro based on a bunch of recommendations. Running this in Chrome Version 60.0.3112.90 (Official Build) (64-bit) I get no window, popup, anything available to me as far as logging into any sites I've put into the password manager app. The app is running on my desktop, Windows 10. If I got to a site (like amazon) where I have a login and right-click the username and password fields, I do get an option for "Enpass" but selecting that just pops a new Chrome window that goes to my homepage. Basically, autofilling doesn't work out of the gate... Edited August 4, 20179 yr by sweater
August 5, 20179 yr Hi, Did you install the Enpass's chrome extension and actived it in Enpass setting?
August 7, 20179 yr Author On 8/5/2017 at 4:03 PM, Ezekiel said: Hi, Did you install the Enpass's chrome extension and actived it in Enpass setting? Yes - I should have specified that. Both the Chrome extension was installed, desktop app was running, and the extension was enabled in the app.
August 8, 20179 yr Hey @sweater Thanks for writing in and sharing the problem you're facing. Please open the Task Manager on your system and check if Enpass and Enpass Helper are running. If yes, please run this command in command prompt and share the results: netstat -ano | findstr 10391 Where 10391 is the port number and if there is no output (blank), please try with other port numbers between 10391 to 10395. Awaiting your response. Cheers!
September 8, 20179 yr On 08/08/2017 at 10:21 AM, Akash Vyas said: Hey @sweater Thanks for writing in and sharing the problem you're facing. Please open the Task Manager on your system and check if Enpass and Enpass Helper are running. If yes, please run this command in command prompt and share the results: netstat -ano | findstr 10391 Where 10391 is the port number and if there is no output (blank), please try with other port numbers between 10391 to 10395. Awaiting your response. Cheers! I have the exact same problem, and the enpass is listening on port 10391. Running Chrome 61 on macOS Sierra. No popups whatsoever.
September 11, 20179 yr Same problem here, Windows 10 (64 Bit). TCP 127.0.0.1:10391 0.0.0.0:0 ABHÖREN 5064 TCP 127.0.0.1:10391 127.0.0.1:62992 HERGESTELLT 5064 TCP 127.0.0.1:10391 127.0.0.1:63325 WARTEND 0 TCP 127.0.0.1:10391 127.0.0.1:63376 WARTEND 0 TCP 127.0.0.1:10391 127.0.0.1:63386 WARTEND 0 TCP 127.0.0.1:62992 127.0.0.1:10391 HERGESTELLT 1576 Tried a lot in the settings, but no result...
October 3, 20179 yr Hi, i have the same Problem, any solutions? Running Chrome Version 61.0.3163.100 (Offizieller Build) (64-Bit) on Windows 10 Version 1703 On clicking the Enpass Icon, only an empty tab opens in Chrome.
