May 25, 201610 yr I have e-mailed in the past about things I noticed when importing from 1password (1pw), but recently I noticed that opvault support was there so I tried another import. I noticed that a lot of the fields from 1pw are not recognized properly and/or you wind up with a lot of blank fields in the logins that you import. This is even after going through every login in 1pw and cleaning them up so they only have a username/password and remember me option set (1pw saves A LOT of garbage when it creates logins automatically). The import process does not recognize 1pw password history so you have a bunch of fields at the bottom of the login with older passwords (and you lose this once you import) It seems like Enpass does not support mutiple URL's in the same way 1pw does so you seem to lose this as well after an import Enpass does not have a facility to save attachments so you lose these attachments on an import as well Importing into Enpass from 1pw seems to just drop everything into the All Items category and you have to go drop every login into the proper category. Please find a way to recognize the categories that 1pw uses and import properly For further suggestions please consider adding the following: Support for multiple URL's (if it's there already please let me know how to use them) Support to save attachments Support to save items such as passport photos, credit card photos, etc.
