August 11, 20179 yr Mapping a template after creation Hi, is there a way to get some fields from a template, into an existing card For example, by surfing on Internet, I could create automatically a new card with credentials, based on the default "identity" card (login, pwd, url). But I want to add extra fields to this card, which are for example already defined in "social security" template, to be able to fill my id and so on. How could I merge the fields of the template, into my existing card? Thanks for your help
August 14, 20179 yr Hey @Denys Currently, Enpass doesn't have this option, but you can manually add desired fields to an item. However, I've noted it for consideration. Cheers!
