March 30, 20206 yr Hi, recently, in the linux client and the android client have not synchronized and show this error code is 907500. I tried to remove and add the configuration again but is the same error.
March 31, 20206 yr Hi @ferdinandpc, We are sorry for the inconvenience caused to you. For quick troubleshooting disconnects the sync from all the devices and reconnect it again. Please revert us back if the issue persists. Thanks for your co-operation.
April 1, 20206 yr Author Hi, i did it with the same result, error 907500 Finally I solved it, was the webdav server, it login but can't write. Thanks for your help Pratyush Sharma. Edited April 2, 20206 yr by ferdinandpc Solved the error
