Syncing Problem
My enpass account does not sync with my Galaxy Tab S5e.  It syncs with the Galaxy S9 phone and my laptop computer W10.  No messages - it simply doesn't sync.  Tried everything- nothing h works.  The version of enpass is the same on all devices.
Hi @Kfl,
For quick troubleshooting, disconnect the sync from all the devices and reconnect it again. Now do some sample change like mark any item to favorite, add a new item in any one device. Now check does the changes are reflected in other devices?
If your problem persists, please share the following details so that we can investigate where the problem could be.
  • Does the Date and Time setting set to automatic on all devices?
  • Does the last synced time get updated on the sync page?
