April 7, 20206 yr Hello together, I have following problem. I have installed Enpass today the first time on android. When I enter my login data in an app or chrome and I want to save it afterwards with the direct link, it always comes the notice on the bottom screen that something wen6wrong while saving the data. Does someone has an idea. Thanks in advance Bjoern
April 8, 20206 yr Hey @Bjoern Welcome to the forum. I was able to find a support ticket you created and reverted on the same. To prevent duplication of efforts, please revert on the same if you have any concerns. Thanks.
April 23, 20206 yr Hey @user5000 We are sorry for the inconvenience caused to you. Currently, Enpass auto-save features for Android works partially on some apps, but we do have plans to improve the auto-save features and will be available with the future version. Meanwhile, you can save the data in the Enpass app manually and then go for auto-filling. Thanks for co-operation.
June 10, 20206 yr Hi @Thorsten79IN, Welcome to the forums! Our Dev team is working on it. Hopefully, will be available in the future updates. Till then, we will request you to please co-operate with us. Thanks!
June 14, 20206 yr I am having the same problem. It all started recently. It seems Android 10 is affected on later updates and its only affecting the ability to pull and store data from the login screens of apps.
June 15, 20206 yr Hey @adamoutler@gmail.com Welcome to the forums! Our Dev team is working on it. Till then, we will request you to please co-operate with us. Thanks for understanding!
